ik kwam zojuist bijgaand subwoofertje tegen... Marquant is nou niet het merk wat ik snel zou kiezen; maar als ik zo eens de afmetingen bekijk zou dit prima naast de accu in de kofferbak passen (moet opmeten morgen)
Marquant MAC-250 Powerful Active 8" Car Subwoofer 210 Watts
The Marquant MAC-250 subwoofer offers booming bass and quality design for your car boot and is the ideal addition to your current car HiFi set up.
The attractive, durable exterior fits in with almost any style without standing too much in the foreground.
With its compact dimensions the subwoofer can easily be places even in the smallest of cars.
Its 8" (20cm) bass driver delivers 150W RMS power that, if you want can really get loud.
All the cables required are included in delivery so you can get going straight out of the box.
Highlights:
Active 8" (20cm) subwoofer with 150W RMS output – 210W max.
Bass reflex design
Large, shock-resistant, low-vibration housing with rubber surface for thunderous bass
Shipped with cabling
Features:
Connections: 1 x Stereo RCA input, 1 x Power/GND/remote input
Adjustable low pass filter: 30Hz – 250Hz
Adjustable gain/level
Frequency response: 30Hz – 250Hz
Signal to noise ratio: 91dB
Output impedance: 8 Ohm
10A fuse
Included:
1 x Subwoofer
1 x Remote control cable
1 x Power cable
1 x Earth cable
1 x Remote cable
1 x Stereo RCA cable
Mounting hardware
User manual
Dimensions:
51.5 x 19 x 23.3cm (W x H x D)
Weight: 5.5kg
http://www.hifi-tower.ie/Marquant-MAC-250-Powerful-Active-8-Car-Subwoofer-210-Watts_i7312.htm
Nu voor 65 euro op Marktplaats...
