I've just bought an April 2001 built Yellow (LD1B) 3L Lupo from Stuttgart, Germany.
The journey was 'interesting' to say the least and took place over 2 days.
It's 1100km from my home to Stuttgart. I set off at around 6am on Saturday morning and headed for the Euro Tunnel.
The News came on at 7am 'The Euro Tunnel is currently closed due to almost 200 immigrants invading the French terminal last night, Services will be delayed...' Oh great!
As it turned out, my 11:20am Train was delayed until 13:50 so I arrived in Calais after 3pm European time.
I now had an 8 hour drive to Stuttgart!
After one stop and around 5 Poirot stories... I arrived at the address in Stuttgart at 22:50 only to find that the seller (Young 20s called Alex, selling on behalf of his girlfriend) was not ready and had gone back into central Stuttgart to get keys, paperwork etc. After several annoyed phone calls later (at 1am!!!) he turned up.
I inspected the car. Found several things wrong with the car (which the seller had not informed me about previously) and we ended up at a Price of €750. This did take around 25 minutes of arguing on the street at 01:30am!!
I strapped the car onto the Trailer and headed off to find somewhere to park up and slept in the back of the Tiguan for a few hours.
The car didn't come with the correct wheels but I had managed to find a set only 50 kms away and bought those at 9am before Setting off back to Calais.
Lots more Poirot later, I arrived at the Euro Tunnel at around 18:30 and then home by 23:00 ready to unload and go to bed!
So the Problems on the car...
It would not always actuate the clutch. That is to say, sometimes you would start the car, put the car into gear and nothing would happen. The gearbox has recently had a lot of work but not by a VW 3L specialist and the clutch Solenoid was not set up properly.
Selecting reverse would only work (when you got it to drive) by moving very swiftly from D to Reverse. A resounding 'clunk' and reverse would work. Just trying to select reverse in a normal way would not work.
I spent a couple of hours last night going through the Basic Settings and now the clutch is happy, the gears all work so I'm much happier
However, a few of you may have noticed some rust... yes RUST! on the left rear sill. I think that the car must have had an accident and the sill has been repaired. The rest of the car is without rust. So I must do some welding!
Also... in the process of swapping the wheels over, I discovered that the rear Brakes are binding. The handbrake cables are seized as are the rear wheel cylinders. I have ordered replacements from VW and they will arrive on Saturday morning.
There are other parts that have been damaged and cable-tied back together so I have many things to do to the car... but it was cheap
MG
