Hello,
So I did my adaptations because I did 32k km from last one and gearbox started to work rough.
After this start stop switches engine off but can't start it it does like 1/5of move with starter and stops. Have to start it manually.
Also when tried to set V on clutch cable it started to act weird.
It showed right Voltage only when ignition off. When ignition went on voltage showed like 3,8-4V.
Gearbox works smooth now but it doesn't start after stopping in traffic jam. Any ideas?
2001 3l.
After clutch and gb basic settings start stop faulty.
Re: After clutch and gb basic settings start stop faulty.
Do you know how to adjust the clutch voltage ?
- dostawca
- Kilometerstand: 217000
Yes I did it.
I've noticed that now in neutral when Intake foot of brake pedal it has few seconds delay before it shows green icon on cluster to put foot on brake. Before it was instant as I released brake. I think this might have to do sth with my problem.
The question is how did you do it .
If you want to adjust the clutch you have to disconnect the hydraulic pump otherwise it,s not possible to set the clutch to the proper voltage.
