Hello,
Has Anyone had a problem of very stiff clutch pedal?
So stiff it crushes steel body of the cable.
I've checked if arm on gearbox is working but it is not jammed. I tried using cable with automatic reset but it keeps on getting loose with this force being used so I bought standard cable with manual setting and it crushed the cable.
I've seen that in 3l arm is around 3-4cm shorter than on 1.7 box and thinking if making it longer will make it go away. Any thought on this problem, Anyone heard of it?
Pedal is so stiff my wife refused to use the car anymore.
Stiff clutch.
- dostawca
- Kilometerstand: 217000
Re: Stiff clutch.
Solved!
Changed the clutch cable to another brand and problem is solved. Clutch works light with Sachs cable and I'm really happy with it now.
