I'm doing a conversion and need help with cables as Google translate isn't that good in mechanical stuff.
I have some guide in Dutch and in Deutsch which neither I understand well enough...
Relay 126 red/black cable is cut and has to be connected to yellow/green in pink plug which cable also has to be cut.
Also, cut the wire on the socket or the plug ?
Next it is relay 53 from pump which can be just put away on shelf,
Second row relay 53 for rear defrost so just make a bridge in it without relay.
And relay 424 I've read to remove it but I've seen some cable in it on photos and this isn't clear from the translator. Can someone check if everything that I've wrote is correct and what to do with 424 relay?
png na jpg program
png na jpg program
png na jpg program
