Lupo 3L from latvia
- Kilometerstand: 240.000km
Re: Lupo 3L from latvia
Made a trip to our neighbours Lithuania, to pick up some parts got aluminium fenders, hood and FSI rear hach with spoiler and iner door lever for very, very good prices.
will go again when I have more time for some more parts. Will post some pics later.
But I have a urgent question, as the temperature is now below -20 I have problems starting, so I need a new battery. My battery is in the rear an now there is a 74AH but the tray is bigger and I cant find info what kind of battery should be there in OEM form?
Most folks place an 80Ah battery as it fits quite nicely. When you measure how much space you have you will be sure not to by a battery that doesn't fit.
Only 4 rear mount batterys
I placed a Varta LFD90.
this is a deep cycle battary so my parkingheater can run all the time if needed.
the battery is 353 mm long 90ah.
rick-3l has the same size but 100 ah normal battery.
you need to take a little strip of metal of to make it fit
so last time got some new parts.
They dont hold back on Using salt on the roads, this is 2days of driving.
And this is the result.......
new...
the rear hatch started to rust too, and the handle and all the mechanism was destroyed.
Today changed the pins in the lock for the boot , so I can lock it finally. Next month is the Yearly inspection so some work will be done, 100% sure I will have to change the rear shocks and do all the rear brakes, and need new front headlights.
Next mods after that would be some 15'' rims + small lowering, rear speakers (got the right oem rear doorcards)
new...
That's one bonus when you use the aluminium panels, no more rust!
Cant find the right section to post, but I wonder If maybe someone have a bad Turbo from the 3L I could buy, I have bought the new core and VNT wheel, but the turbo have bad threads for the VNT screws!?
Lets try in the "WANTED" section: http://www.3lvrienden.nl/viewforum.php?f=7
hello, maybe someone have some pictures of the stearing rod/ tie rod assembly , because the last owner have messed it up, because one tie rod is with the bend the other is streight, and mounted from the lower side.
In the OEM diagram it shows the tie rod mounts form up (with the nut in the lower side), with the bend bending to the rear!
Is this way the right one??
Hi, my lupos gearbox control unit started leaking and working poorly, the car was undriveble! So I bought a crushed 3L donor with a manual conversion lade already (in reality I bought a red 1.7sdi to drive around when mine was broken, sold it , made a profit and, then bought the manual 3L), So i got the manual conversion, turbo, steering rack, halfshafts that I needed for my car! swapped the Anti Shudder Valve to the pre 2001 engine type so it doesnt leak air from the clip type connector! The connversion was poor, so I had to redo the exhaust and shift cable holder!
The next wrongdoing is the i think the ECU!!!! From the part code it is a 1.4TDI ecu, so my problem now is in vagcom - engine managment - measuring block- group 11 log
The N75 duty cycle is ~24% at IDLE (if i look at the turbo the actuator is fully opening the VNT) and it drops when the boost start to exceed the maximum value, but still it can do 2300mbar, even if the maximum requested is 2050mbar!!!
So my idea is The ECU is an unmodified 1.4TDI with the WASTGATED turbo! Maybe someone can confirm my worries? or maybe there are other cases this can happen???
hello, as I understand the 3L glowplug relay / control module should be this one but i cant find it anywhere, does anyone know where to find it?
- Wolf
- Echte naam: Dirk
- Productiedatum: 03 jan 2005
- Kilometerstand: 257.000
Yes. Look in the link under my message. You'll find a burned one. Search for 038907281.
The short version: look behind the drivers side splash screen in the wheel well in the front side.
